smithgun2009
- Nov 29, 2009
- 15
I had a sudden loss of power and RPM drop--engine oil blew out thru crankcase vents and went to bilge. Refilled oil and still not enough power to plane out boat. Ran engine on trailer with flush kit and found water coming from exhaust outlet-(280-290 model I think with exhuast thru outlet port and not prop hub, my first time with this type system). Only had boat about 2 months but had no water that I noticed coming from exhaust port when flushing from salt water trip. Usually on auto engines this is an sign of head problems as well as over pressure in crankcase caused by blow by on valve stems. Thanks for any info before starting pulling things apart.
