83Evinrude
- Sep 3, 2008
- 290
I'm winterizing my Volvo 5.0GL-D and SX outdrive. The engine has two drain plugs on the block (one on each side) and one on the rear of each exhaust manifold. There are larger brass plugs that thread into the cast iron and smaller brass plugs that thread into the larger plugs.
To drain the block and manifolds, do I need to remove the larger plugs or only the smaller ones? When I removed the smaller ones a fair amount of water came out, and on the manifolds it was noticeably rust colored does this sound normal?
If I understand the manual, I should also remove both hoses from the raw water pump on the front of the engine, and turn the engine over (not start it) a couple of revolutions to remove water from the pump. It would appear this would also drain the power steering cooler that is located near the rear of the intake manifold. Correct?
When I drained the lower unit oil there was no water present but I did see some debris. There was very fine particles that appeared to be suspended in the oil and a very small amount of what I would describe as small metal flakes. The drive seemed to work fine this summer and shifts into forward very smoothly, shifting into reverse is much harder however. Does this sound normal?
