craze1cars
- Dec 26, 2004
- 1,822
Hello,
I'm just getting everything into perfect tune...service manual procedures for setting ignition timing basically says warm it up, make sure choke is wide open, set the idle speed, hook up the light, and compare to specs, which should be 8 BTDC at 600 rpm. I will be using an accurate shop tach.
My question: Is this OK to do on muffs in the driveway? Or must the outdrive be submerged for this timing check to be accurate?
Service manual does not specify...though I know in the fuel section they do specify that idle speed must be set with boat IN the water and IN gear. But what about timing? Would be much more convenient to do this at home in the drive...but I'd rather it be perfect than convenient...
Thanks.
Thanks.
