Re: 290 volvo shift cable replacement
I replaced mine in the spring. not tough at all. You'll need to access the inside of your control box. Some are harder than others. You also need to know the length of the cable you need. I found some numbers on the outside of my old cable and was able to determine what the length was.
Good Luck!!
