I just completed repairing a lot of items on my boat with help from these forums. Thanks.
The last issue is the Sea Water Pump. It has been completely overhauled. Everything is new and original Volvo except for the case. The case is deeply worn with .030in or so grooves on the cover and back (not on the surface where the impeller runs) but it was pumping water even with several vanes missing on the impeller prior to the rebuild.
If there is a leak causing it to not create a vacuum I'm thinking that would be between the sea water inlet and the pump. Everything after the pump should be under some sort of pressure. So an air leak causing a lack of suction must be either in the pump or before it. Does that sound correct.
Thanks.
Thanks.
