Hi All, I've got a '97 Four Winns with a Volvo 5.7GL and SX drive. The engine had been running reliably this spring and summer but has recently developed a problem.
When taken from neutral to forward gear, the engine sputters and usually stalls. It was possible in some cases to put the lever in forward and quickly add a lot of throttle to keep the engine going, but clearly there's a problem somewhere. Interestingly, the engine goes smoothly into reverse and power can be added slowly without any sputtering or stalling.
The nature of the problem (stalling only in forward, not reverse) suggests to me that it is likely an issue with the drive. Any ideas or similar experiences? Based on searching other threads, it looks as though shift cable adjustment or replacement could be a potential solution, but many of the threads I looked through were related to mercruisers instead of the volvo. I've got a lot more experience with engines than sterndrives...
Any possible repair info appreciated!
