I have twin Volvos in my boat and now the Port engine started to run rough and usually stalls when I put it in gear. Changed cap/rotor/plugs but still the same. Checked for error codes but none present. These engines are TBI. In neutral, it starts right away and runs to 3000 rpm no problem. As soon as I put in gear, engine runs rough and stalls. Checked prop to be sure it was clear.
Fuel pressure 30 psi and fuel/water sep just replaced. Hope someone can direct me to problem area.
