1992 Chaparral 28' with 431B and DP stern drive.
Rebuilt engine with all new water pumps, manifolds/risers, thermostat and a non professionally rebuilt carburetor and what I mean by non professional is it was just done by a normal mechanic and not tested on a test motor etc but rebuild kit was used.
Overheats randomly at both high throttle operation and when idling in gear for extended periods.
This is the motor with the power steering pump.
A little history. We put in a Jasper rebuilt motor after the original got hot and put a hole in the piston.
The out drives were rebuilt about 3 years ago.
The boat is raw water cooled and is in salt water.
Ideas???
Ideas???
