Have a solex 44 carb on my Q125a and noticed there is a spring that should be on the bottom side of the linkage of the carb arm where the cable runs threw the spring .
My spring was on the top ,I tried to change it around but the cable is to long to allow that .08 inch on top,as in stated in the manual . how do you make the cable shorter.is there an adjustment closer to the throddle lever.
