andria garlick
- Jun 15, 2009
- 17
I have a 2003 fourwinns with twin 5.0 Gxi c motors the port engines run fine in slower speeds, however when a throttle up the engine heats up with in a minute or two. the engine automatically throttles down to about 2,000 Rpm I then put in reverse for a minute. Then I put it back to forward And then run it at about 2000 rpm it will cool back down an I can throttle up again in a minute or two. then it heats up again the motor shuts it back down to 2000 rpm. however it will remain getting hotter if I dont put it in reverse an do the step I just discussed. I replace the impellor which looked perfect. so I dont thing that is the issues. Do anyone have any suggestion on what to try next.
Ron Garlick
Ron Garlick
