Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Volvo Penta SX lower unit oil change
  • Volvo Penta SX lower unit oil change
    I'm wanting to change the oil in my SX outdrive. I don't have the manual 'yet', but just hoping some one can lead me in the general direction in which I need to go.
    Volvo Penta 5.0GL with SX outdrive.
    Re: Volvo Penta SX lower unit oil change
    Need a pump (oil MUST go in from bottom) and about 3 qts of factory synthetic gear oil. Remove bottom plug , dipstick and fill hole under the shift cover . (held on by 3 5/16 bolts). Clean the magnetics on the plugs and refill. I always run abit and then re check, I have never needed to add any extra, but worth piece of mind to me to recheck. I always check fluid level after brief run after changing any of them. Not being a jerk, just as FYI, get a factory manual, the factory manuals are only ones worth a darn and not that expensive, do not waste your time with aftermarket manuals, they are junk.
    • #3
      You can download the manual for your outdrive at the link below.
      http://www.4shared.com/account/file/...ce_Manual.html
      Without full model numbers for your engine, it's hard to say what you have. No model number, no Serial number, not even a year to put us in the general vicinity.
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Thanks for the responses guys.
        The boat is a 2005 Caravelle with the 5.0GL-E with the volvo penta SX-M Sterndrive. That's a bunch for the link, it's extremely helpful.
        Can you please post a similar link to the engine.
        One last thing. I'm confused on how often one should change the engine oil and lower unit oil. According to the manual it says 100hrs or once a season. What if I only use the boat 30-45 hours a season??
        thanks,,
