volvo penta 270 thottle will not reverse
Status
Not open for further replies.
jhb
Looking for suggestions: 1985 bayliner capri 2.1 with a volvo penta 270. While at the lake this weekend the thottle became hard to pull into reverse, then as the day went along the throttle would not move into reverse at all.
Any suggestions,
thanks, John
bruceb58
Re: volvo penta 270 thottle will not reverse
Sounds like your shift cable is failing somewhere. More than likely where it attatches at the sterndrive.
Don S
Check the gear lube. Make sure it's not milky (water) or burned (?????)
jhb
Thanks for the quick reply, stupid on my part I should have checked a little closer. When I went to take a closer look at the stern connection a rock was lodged under the lock collar. The shifter is working both directions again.
Thanks for your help,
John
quadragin
Should the Pentas be hard to put into reverse while engine off on trailer?
Trying to find out before we go to the lake. Everything seems great in the forward postion.
Hard to put into reverse, and I did not know if the engine needs to be running for that???
Status
