fordpwr460
- Feb 20, 2018
- 6
HI folks, new to the board, see if anyone can help with a wiring diagram or ideas for this. I got a fuel pump that does not work, even after its running, it will run off carb cleaner/gas, for a few seconds then out, (no fuel obviously), this has a small slimmer relay PN 3841366, it gets better though.....this all started when the old fuel pump popped a fuse, so I hard wired the pump thinking it just got gummed up. huge POP, smoked. OK, so I hard wired a locked up pump....it was dead anyway right!....bear in mind no boat wiring was disturbed, this was bench checked. Now with a new fuel pump, I got no power to the pump, while cranking OR already running. So i'm thinking these diodes are popped? (fuses all checked and replaced 1 and has not popped again). Also a big note,,,,when I probe the wires to the fuel pump, it has ground, but when I put the test light on the ground to pickup "HOT" it immediately spins the motor? power going backwards up to the relay and engergizing the start wire? that AND the boats starter auto-engages WHILE its running!! went from a locked up fuel pump to some nightmare!! any help or ideas would be appreciated!! thanks
