So I bought my first real boat this fall,1998 fourwinns with the vp5.0 and cobra/vp sx outdrive. I was changing the lu oil and discovered that the drain hole threads were shot/stripped as I tried to install the plug it never got tight. Which irritates me cuz this boat was maintained religiously every year at a vp dealer. Someone has been overtightening the plug for a while now. So I had the engine block winterized and pumped full of antifreeze. Question is...should I remove the outdrive to fix the lu and inspect the gimble and bellows this winter ? I ordered a longer screw that fits the drain plug and I honestly think just the longer bolt is gonna fit tight in the lu and seal it up. But was wondering if I should remove the lu just for inspection...no I don't have the manual for it yet but looks like 6 bolts and unhook the shift linkage and it's off? Then for reinstall I need a tool to like things up upon reinstalling? Looks like I can buy the tool for $30? Is there anything else I would need or any reason I should not remove outdrive for the winter? I'm hoping everything in there is good but figured this is the off season, perfect time to inspect things on a "new to me" boat. Is there anything special I need to know about adjusting the shift linkage ? Leave the drive in neutral upon removal, or forward, or reverse?
