i cant figure out how this is supposed to be set up since the bracket will interfeer with the outdrive mounting properly from what i can tell. i cant find any photos or videos of anyone setting one up
The second link is not for your outdrive. The first one is.
BTW...that little bracket that is around an inch long with a bolt through it is not supposed to be there. It is supposed to sit back in the slot a few inches toward the transom. The first picture in post#2 shows where it goes.
You also have a hose sticking out of the water inlet. That is not supposed to be there either.
