This is my first input to this forum. I'm sure my problem had been discussed many times, but I can't find my exact problem discussed. Recently, my temperature started rising towards 175, so I decided to change out the impeller. No change. I took off my risers, which really looked in bad shape, so I replaced them with new ones and new gaskets. I looked into the manifolds ports when the risers were off and there was some small amount of blockage that I cleaned out. The passages seemed o.k. Ran the engine again. No change. Since my circulating pump was original, I replaced it along with a new thermostat. Still no change. I back flushed from the raw water pump to the outdrive. Water ran freely. I forward flushed through the thermostat housing and water is running through the system and into the manifolds. However, I see no water coming out of the two nipples that come out of the sterndrive. Should there be water there? Do you think I need new manifolds? Could use a little help on this one.
