Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone elses topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when its posted at the end of someone elses topic. And those answers will be specific to your particular issue.
See more
See less
Oil running out of exhaust
  • Oil running out of exhaust
    I recently acquired a 1976 Fiberform Baja 240 kcs. The sterndrive is a Volvo Penta AQ 240A/280. The boat had sat in an outside storage lot for the last 15 years. No idea if it was winterized in any way back then so I am just starting to look things over. I installed a new battery to see what I am up against and as I lowered the outdrive, quite a bit of oil poured out of the exhaust. maybe a fourth of a pint. Any ideas where it might have come from.
    Just getting started
    back then I believe that the drive even had engine oil in it.
    pull the drive, pressure test it.
    I would also pressure test the cooling system on the engine
    also, any boat that sat outside neglected for 15 years is going to have rot somewhere. a 42 year old boat will guaranteed to have rot somewhere.
    1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
    Past Boats
    1970 Wooster Hellion - Merc 9.8
    2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
    1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
    What’s behind you doesn’t matter.Enzo Ferrari
    • #3
      Thanks for the suggestions, I'll do that and yes, most of the exterior wood is shot. Fortunately, I got it for next to nothing. Just needed a project.
      • #4
        remember, the boat structure is wood with fiberglass around it. this includes the transom ,stringer, bulkheads and floor..... most likely you will have to gut the hull down to the outer skin and rebuild.
        free boats or nearly free boats are the most expensive in the world as they cost the most to bring back to safe and working condition
        Past Boats
        • #5
          Is it solid oil or slight diluted ? It may be that the previous owner had ran 2 stroke through her before storage or oiled the crap out of everything.
          • #6
            It's solid oil. Looks like it's right out of the bottle.
            • #7
              With the drive down remove the dip stick from the top of the drive to see if the oil came from the drive. Hopefully it did not. There is only a few O rings which seal the upper & lower gear housings to the mid section. Get a genuine Volvo service manual and you will see how easy it is to service.
              Kenner, Louisiana 1980 Donzi 18'. 2+3 6.2 MPI Alpha 1
              • #8
                With the drive down I checked and the dipstick is dry. No oil
                • #9
                  Is it gear oil or engine oil. Gear oil is easily identified. Horrible stuff and stinks rancid
                  • #10
                    It's engine oil
                    • #11
                      Clean engine oil is what you will find in an AQ Volvo, Like I previously posted get a Volvo manual and genuine Volvo seals and O rings, they are nit cheap but you get quality. 30# oil is what Volvo always used in the AQ drives.
                      • #12
                        Sorry it took so long for me to respond but just to be clear, instead of lower unit lubricant, I should use SAE 30 weight oil?
                        • #13
                          Yes.
                          Just so you know 30 SAE viscosity engine oil is around the same viscosity as 85W SAE gear oil.
                          1998 Wellcraft Eclipse 24 Cuddy
                          Volvo Penta Duo-Prop 7.4L "LK"
                          2006 Sun Tracker Party Barge 21
                          Mercury 90 4-Stroke FI
                          "Common sense is not very common"
                          "Failing to prepare is preparing to fail." -- John Wooden
                          • #14
                            Thanks, that's good to know.
