whitebunnyflock
- Jul 12, 2017
- 64
The owners manual says to remove a plug on the port side of an SX drive in order to get the water out that appears to be near the bolts that hold the outdrive on the transom.
However my SX-M does not have this plug. There is a plug on the starboard side however and I am wondering if it is the same thing? Just want to make sure i completely winterize the leg as well. The gear oil has been changed already and i have lubed the u-joint and gimbal bearings as well as having replaced the u-joint bellows and the exhaust bellows.
