I have a 1997 Parker 2320 with a AD41-P and what I think is a 290DP drive. I noticed I could not trim up the drive while out last weekend. Down works fine. The digital gauge (872498) display went out and the top red led light is blinking. The switch is a dash mounted 3 button (3855650). I switched around the relays on the transom, still no up function. I switched around the relays behind the dash gauge, still no up function. Down still worked fine after switching around the relays.
Got the boat home and did some additional troubleshooting. I noticed there are 2 green wires coming from the pump motor, 1 has a tag that says attach to motor housing, that one is attached there. The other wire is not attached to anything and has no tag on it! Is that a ground also??
When I turn on the ignition, I can hold the override (red) and the up button at the same time and get the drive to move up for about 2 seconds until the red light on the gauge starts blinking again. If I turn off the ignition and back on, I get the same result. I raised the drive all the way up using this process. Down still works fine with no issues.
I have searched through the forums and have not seen this problem pop up yet. Any help would be greatly appreciated.
