I have a 1999 Reinell, Volvo Penta 4.3L GL. I have had 3 separate occasions now where the boat fires up perfectly at the launch, we drive to a beach, sit for about an hour or so to let the kids swim. We then hook up a tube to take the kids out, as we are getting on plane the boat just dies all of a sudden. All 3 times it has been the same exact scenario. For some reason fuel just stops getting to the engine. The last time I took the fuel filter off and it was drained about half way and the carb. was empty as well. When I try to get it started out on the water zero fuel is coming through the fuel line. Each time when I've gotten it home it fires back up again if I try it in my driveway. I've checked everything I can think of so I brought it into a shop and they weren't able to identify any issue. It fired back up again with no problems there as well. The fuel filter is fine, the fuel pump is working, they checked the fuel pump relay and that was fine. I'm a little at a loss on what the actual issue is, but obviously its not the most relaxing thing to take the boat out wondering if/when it is just going to die. Any suggestions would be much appreciated.
