GMTK
- May 27, 2016
- 158
Out of curiosity - are the u-joint bellows designed so that NO water at all gets in? Specifically, I have a SX-M and am was wondering if they outdrive is designed for no water to get in. Only reason I was thinking about it was because the gimbal bearing calls for the same grease as the trailer bearings which it typically a water-resistant type grease.
