fourwinns1996
- Aug 19, 2017
- 16
5.0FI Volvo Penta Stalling Issues
Today
I have 1996 Four Winns that has sat for 7 yrs. when I first pulled it out this spring I had the fuel pumped out and 91 octane non ethanol put in along along with some Lucas fuel cleaner. Motor would not start! Had it taken to the marina for further in investigation! Found the fuel injectors were stuck open. Replaced the fuel injectors took it to the lake and it would run but acted like it wanted to stall at 3000 rpm then would pick back up and run at 3000 then stutter again. Decided to change the fuel filter. Started it up and it ran for about 15 seconds then stalled. Could not get it fire back up. Found fuel coming out on the air intake. After much debate I unplugged the low pressure pump and cranked it over several times before she fired! Tried pluggging the low pressure pump in again and within 5 seconds stalled again. Unplugged it again and fired it back up! Plugged it back in just to be sure and yep stalled in 5 seconds again. Low pressure pump flooding it out? Is it the pump or electrical running the pump continuously?
Today
