BarryTurano
- Oct 26, 2014
- 145
Pretty sure most of you know that for 3 years now I have had all sorts of motor issues with my boat. I will not go over all of the disappointments, lost sleep, monies spent and aggravation. It would take too many pages and there is so much I probably could not remember it all. Lets just say the beginning issue was a parts changer (I won't even call him a mechanic) that first surveyed the motor and told me it was good. He was recently the subject of a post on another site.
But I digress my current mechanic was going by the information that I was given regarding motor condition. After an untold number of hours and others looking at the boat, we hauled it out. Performed leak down and compression test. Stopped after 3 cylinders. Here are the results: First 3 cylinders tested were 180 pounds compression 10 % leakage. Next was 150 pounds compression 15% leakage. Next was 110 pounds compression 75% leakage. Stopped at that point. I was running a maximum of 7 cylinders, probably less. No wonder it ran like crap if I went past 3500 rpm's.
So I am re-powering with a 5.7 which will give me about 300 HP. I had a 5.0 which was 250HP when it was fuel injected. Probably was 225 when I went to carburetor and probably 200 HP as it is now.
Sometimes when a deal seems to good to be true. IT IS!!!!! Lesson learned.
Mikes Marine Service in Hampstead is doing my re-power. Should be ready middle of next week. Marine Service and Repair will still be doing my service work. Hopefully the man up stairs keeps the fan off for the fall. Need to break this motor in right and can't think of a better way than running it and getting the deck bloody.
