Having issues with a 3.0L GL-MMDA. Motor sit for roughly 3 years. I changed normal parts and drained the gas before attempting to fire. Mechanical fuel pump was bad so swapped to electric pump. Rebuilt carb. It fired up, ran it down the water bout 20-30mins. Running bout 3500rpm and would sputter. Went to turn around it died (didn't have idle dialed in yet). From there on it will run smooth up to 1800 rpm but above that it starts backfiring, bucking, sputtering etc. New coil same issue. So far I've replaced cap, rotor, plugs, wires, fuel filter, oil change, rebuilt carb (took back apart to blow out and make sure everything was right), and fuel pump. Adjusted timing by ear and it wouldnt help or hurt the 2k rpm issue. Compression is good 150-155 across all cylinders. Ran off fuel tank and 5gal container. Thanks.
