Shaper79
- Mar 25, 2016
- 233
Ok. So my will no longer get past the 4200 rpm range with the 19 pitch used to hit 4800. I did all the rule of thumb tune ups and checks my low pressure fuel pump was only at 4-6 psi. Pulled both pumps and checked screens for paint chips. Non we're there. Checked any syphon valve it's good. The fuel filter is only put on last spring and maybe 3 tanks of fuel threw it. And if got another on the way. The low pressure fuel pump is Winning but my throttle body jets are spraying perfectly when I reve it up on the muffs. So I need a low pressure fuel pump for the 5.7 GSI PEFS. Carter fuel cell. I could not find it on Iboats. Any help I need to order one thx
