One weird thing might be a fluke....but with key in on position I went to disconnect the main plug and when I was in process of disconnecting it the dash started alarming which I guess could be expected as it see power loss but I also heard noise in my throttle body like a hissing sound like air being released. I then completely disconnected plug and then reinstalled it...Boat fired up ran for about 7-8 seconds then died and wouldn't restart.
Since the engine ran after reinstalling the main wiring harness connector that goes between the engine and helm (dash) components, 99.5 % your non starting issue should be related to something not making perfect connection within the wiring harness losing contact possibly due to slight engine vibration... For now you'll want to concentrate on the wiring harness until you know for sure it's right before moving elsewhere which then since the engine died you may have temporarily ran out of fuel within the fuel filter / fuel pump either due to the fuel system is still priming itself up or the fuel pump is not activating due to a power loss within the main wire harness.
Did you prefill the fuel filter before installing it?? It's best to do so.
Since the engine ran, you now know you have had spark which helps alleviate an issue with the Crankshaft sensor because it worked when the engine ran, which it also told you the RPM gauge did receive a signal at one/that time in order to allow the engine to run too. You just don't have either full 12v + power or possibly - ground at the dash right now which might show at the 12 volt gauge at key-up depending on what wire is losing connection....Or one of the other many wires within the main wire harness between the helm and engine has lost connection not allowing the engine to run.
Your crank sensor is most likely fine at this point, put it back together and work on the wiring...Also as Dave-R mentioned....Are you getting power to the fuel pumps? Because when watching your video, I don't believe I heard them power up which would be another indication of lost power/connection.
The reluctor wheel should look like this one,
http://forums.iboats.com/forum/engi...nboard-engines-outdrives/566975-reluctor-ring
