Quick question. My 5.0GI PWTR was not getting up to temperature during its first run, it did this last years. Would get up to about 130 degrees on the gauge and no higher. (Just head this off, I have never had a bad impeller that lost vanes)
So I replaced the T-Stat and cleaned up the T-Housing. Fire it up on the hose to check for leaks and see what happens. Seems to slowly get up to operating temp and holding fine, but I noticed while I was touching the hoses that the big inlet hose to the Circulating pump (not the raw water pump) seemed hot to the touch. Is this normal?
Risers and manifolds are nice and cool, plenty of water coming out the back
