I just bought a boat that has a Volvo 7.4 Gi PWTR engine. It is running great, but the LP fuel pump starts whining after it has been idling about 3-5 minutes. It sounds like it is caveating, then it passes the air and a few seconds later the cycle starts over with a quiet whine that gets louder until it passes.
I found a post with the exact symptom, but he ended up replacing the pump with an aftermarket which I didn't want to do. The PO told me this pump was replaced a while back and the boat hadn't been used but a few times since. I am thinking maybe it is somehow sucking air. I put a new filter and yesterday I removed the filter and topped it off with gas to ensure I didn't have trapped air in the filter. No change. I have ran it with the gas cap off. No change.
I am wondering if when they replaced the pump on of the fittings is not completely sealed allowing air to be drawn in??
The pump gets hot and I would like to correct this before I damage the pump, or end up stranded somewhere.
Thanks
Thanks
