I just acquired a 1997 4.3L penta that hasn't run in 10 years. I'm going through the motor to see if its worth messing with. i haven't tried to start the motor mainly because the batteries are dead. Just wanted to make sure it wasn't locked up. I pulled the plugs and removed the belts and tried to manually turn the motor with a breaker bar on the harmonic balancer it moves easy from the 10:00 to the 2:00 position then stops. What gives?? Is it in the out drive?
or is it trashed? Where do i go from here? Thank you in advance for you advice.
