Hi
I was trying to trace a yellow red (ignition wire ) and all of a sudden fuel pump start working . key was not in the ignition .
i use the key trying to turn it on/ start / off nothing happen (no surprise here as i have an issue with neutral switch ) .
eventually i disconnected the battery . if i reconnect the battery the pump start back on .
Any idea where to look ? My guess is behind the dashboard i might have made a wrong connection but where should i look for?
My boat is Larson , engine is 5.7GS PLKD if this is relevant.
Thanks
Thanks
