Buickgsman
- Oct 2, 2015
- 56
I had a snow day today and decided I am going to start to plan the removal of the gimbal bracket from the transom. Before I get in over my head, I figured I would ask the experts so I don't make more work or expense for myself. I want to remove the entire assembly so that I can repair the gimbal from someones heavy handed outdrive removal. They went at it with a pry bar and really did a job on the mating surface. Additionally, they went at it with some black paint for an unknown reason. I want to have the gimbal surface tig welded and cleaned up and repaint the entire assembly. I will also need to do the same repair on the outdrive itself as it has a few prybar scars and it will get a repaint and whatever else it needs to be 100%. Am I making a mistake wanting to remove the entire assembly from the transom? or should I remove everything else but the bracket? What to do? And is there a good source for a manual? The boat is a 98 Four Winns Horizon RS and the engine is a Mercruiser 5.7 in place of the original 4.3v6. I just started reassembly of the engine rebuild this past weekend and I am hoping to have my ducks in a row so I can put the boat in the water sometime this summer.
