Hi guys
I replaced my thru hull inlet ball valve and in the process had to remove the power steering oil cooler - a bit of fluid escaped and I ran the engine prior to topping up the reservoir (just slipped my mind!) I topped it up straight away but there is a squeal/growl that comes from the power assist ram at the stern drive (not the pump on the engine) when I turn to port or starboard - any tips on how to sort this? (I assume I may have to bleed it but cant figure it out?)
cheers
cheers
