Hi. Stripped engine. Now down to the tricky bit.
1.do i set TDC before removing head?
2. Whats the next move? Do i just unbolt the valve cover then rocker arm? And does it come out in bits? Will valves start dropping out :/
3. On my tamd22, tdc was on the flywheel, and its was TDC all the time with the hole lined up, on these could it be on the wrong stroke to be TDC, i.e. 180 out??
Has anyone got tourqe settings for parts ive unbolted.
Cheers everyone
Cheers everyone
