After changing out my bellows and gimbal bearing, I am having trouble tightening the Outdrive to the housing. I was able to slide the leg on far enough to have a few threads showing, but it seemed to bind up there. I began tightening down the new nylock nuts, but it just seems to be that there is too much resistance. I don't want to force it any more than I already have so I loosened off the nuts and will remove leg to check things out more closely tomorrow. My alignment bar slid in all the way nice and easy, so I'm wondering what can be wrong. I know I should be able to hand slide the leg all the way in once the spline is lined up. Is it possible for the bearing gimbal to be slightly "cocked" so that the shaft is binding? I would think that it would straighten itself out once the shaft continued moving through it. I believe I have followed all the procedures listed in my shop manual so I'm kinda stumped. Any ideas?
