Hello all! Pls let there be someone that knows this??
Fuel pump does not seem to work and think it might not have worked since at least a year?? Possible?
Boat has been sluggish and have been chasing performance issues as it has trouble getting up on plane.
I replaced the fuel filter thinking that might be an issue. Did not refill the filter as I did not have a spare can of gas. I know bad Craig!
Turned the key and no sound from the fuel pump. Cranked it. Ran perfectly. About 2 min later. Went dead. No fuel.
Jumped power to fuel pump and it sounds good, but still does not seem to pump fuel.
Removed fuel pump and screen looks clear.
Checked wires going to relay harness and information on the side of the relay says that positive wire for power to the pimp should be going to 87a? But it is currently going to 87. Was I given the wrong relay?? Wiring diagrams that I have den on this site show that 87 is the right connector for the power?
Should I just move the power wire to 87a?
Replaced
Can't seem to find out correct wiring to the relay pins. I am and wiring to those pins. What I can't find
Replaced
