I'm doing a tune up on a 2003 Campion with a Volvo Penta Red Block 5.7 GXI and I have the NGK BPR6EFS spark plugs and the old plugs are the exact same and I checked the gap on them and they all have a .045 gap and the engine tag states .060 so my question is do I follow the .060 with the NGK? Also I just purchased this boat and I took it out to the lake and it ran crappy when it passed 3500 rpm and would bogged down but only if the engine was warm. I found 1 spark plug with a gap of .050 so I'm not sure if that would cause a problem with that cylinder miss firing as the others were set at .045
