Assassin3F
- Aug 23, 2016
- 44
This one is a real trifecta...its actually worse than that since what I have found so far scares the crap out of me about what I am going to find next...there is a real downside to understanding potential problems it seems...
I recently bought a 2000 Wellcraft 175 SS; The Power Package is a Volvo Penta SX 3.0L (engine info 3.0GSPEFS; built by GM in 1999) I grew up around boats but am tackling a number of issues in the engine compartment and I am looking for advice. The engine runs but I am told it is a very hard cold starter but good when it warms up (more on that below.) When I looked it over there were a number of items that I missed prior to purchase or did not think to check so I am now going over the engine with a fine tooth comb. I know it runs but I don't want it to run until I am sure it won't kill the engine or outdrive.
Issue #1: I have a battery drain...a big one enough to bleed it dead in approximately 3 days. I think it is located in the bilge pump (which is the only switched device which does not work) so I am going to start by cutting that circuit out and putting in a new device. Battery is recharged but disconnected at the positive terminal at the moment.
Issue #2: An ungodly amount of fuel vapor around the engine and yes this bothers the crap out of me. I have removed the engine cover and bulkhead for access purposes (I am 6'3" 250, squeezing behind or under an engine is a little difficult) but I keep the boat covered when I am not working in it and the cover does go over the fuel cap but the boat is stored and worked on out doors. There is no fuel or water in the bilge or under deck spaces but the vapor build up is intense, to the point that I bring out a box fan when I uncover it and blow fresh air all over the vehicle prior to getting in then leave the box fan blowing into the engine and bilge spaces to KEEP them clear. I am very concerned and I am looking for advice on dealing with this issue. There is no fuel in the bilge or seeping out into the under deck spaces. It has rained a couple of time and small amounts of water have gotten in the boat (less than a 1/4 cup) with no sheen of fuel/oil smell/texture) The hoses appear to be newish or at least in good condition, but I am going to inspect the penetration points at the tank and hull interface this evening.
Issue #3 in conjunction with #2 above. The carburator choke (thermostat housing I believe) is broken. As in a chunk of plastic is missing from the housing and you can see inside. I believe this is supposed to be able to pull a vaccum and it is clearly a gigantic vaccum leak. This is something that actually gives me a lot of hope with respect to the fuel issue. I am going to buy a new base gasket for the Carb and a new choke cover this evening from an auto parts store (I know you are supposed to use marine parts but I think the choke cap has to be in a vaccum to operate correctly so it should be the same regardless of carb??). I suspect the float needs to be replaced as well.
What I think is happening is the boat is outdoors in the sun all day and the fuel in the tank is heating up enough to lead to a slow drip in the carb. I think the float is filled with fuel and not shutting off the needle valve in the carb and the hole in the choke housing is letting the fuel evaporate all day. What I am hoping is that I can swap out the float without doing a full strip and rebuild.
I am going to inspect the impeller, and outdrive before I try to put it into the water (also the bellows etc.) and I am contemplating pulling off the drive before making any attempt to flat the boat (by the way this site gave me a great idea for a cheap way of getting the drive out and supported) but the following are my questions concerning the above issues.
1. On the battery drain if the bilge isn't the problem what is the best tool for tracing the system? I have a multi-meter and have been following a procedure where I disconnect the positive terminal and bridge the gap with the meter then disconnect devices until the voltage potential drops to zero. But no dice. Now that I have obtained a wiring diagram (courtesy of this site). I realize that if the short is in the grounds (any of the grounds) this will not find it since they are all spliced together into a type of circuit bus. Is there a tester I can use? I saw a couple at harbor freight that were cheap and 'might' help me but I am unsure of what device to use or how to configure the system so I know I am doing the right procedure.
2. Can I pull the fuel sump off the Carb without doing a full rebuild? I know you are supposed to do a full rebuild but I don't have time at the moment...what I am wondering is if I can just pull the sump off right now and replace the float and choke housing put a couple of new gaskets on and see if that fixes the fuel problem.
3. I read out here that you can run your hand or a damp rag on the fuel lines and if you smell gas you know what you need to do with the lines. If that isn't the problem how do you tackle the rest of the fuel tank? Some of the tank penetrations are visible in the engine compartment or through an access hatch but I think there is one that is beneath the deck and I cant get at it without tearing up the floor.
Any advice or responses are appreciated in advance...I am certain I will have more issues as the 'inspection' goes on.
