Volvo Penta 1999 4.3GL PWTR
We replaced the starter a few weeks ago and the boat was starting great except for this unresolved issue (see link below). I went out last night and it appeared the battery was dead due to the bilge pump running from recent storms so I hooked it up to a charger/starter. After doing that the starter just spins fast and does not engage. A few times it sounded like it might ?almost? engage, but not enough to turn the engine. This is a brand new starter ugggggggg! :-(
The battery appears to be ok. We swapped out with a car battery just to try and it did the same thing (spun fast).
Is there anything else that I can check before pulling the starter and having it bench tested? Relay? Ground? It is a pain to get to the starter on the bottom of the engine, so if there are a few things that I can check ahead of time I would like to attempt.
http://forums.iboats.com/forum/engi...ystem-trips-and-electrical-system-goes-dead
