Acceleration problem on a 252 hour Volvo Penta 5.7 GiC 300 - R
SteveB72
SO.... the engine peaks at 3700 RPM not 5000 accelerates normally without any check engine lights and then slowly begins to open up to max RPMS, when I say slowly over a period of 3 - 4 minutes? Where do I start to look I'm guessing a new fuel filter - because it takes 3-4 minutes to build pressure. The boat is garaged in dry storage - just started acting up - I would like to learn how to service or where to begin looking to fix the problem.
Ayuh,.... Welcome Aboard,..... Don't just change the filter, but examine the Contents of the ole one for things other than gasoline,....
