a little background:
the boat was bought this year with 850 hrs on it, the PO told my friend no issues about the boat however it has an overheat problem, which I have a seperate thread regarding, now I find that it has a stalling /no start problem,
the boat has a constant stalling problem, which was there prior but not as constant as it is now, now it is not running more than is is running. i have checked the fuel pumps & i am not sure i am getting enough fuel pressure. the shreadder valve on the fuel line is reading 14psi, the schreader on the rear fuel pump assy is ony 10 psi, i have read that i should have 29psi . the boat has throttle body injection. i have read about the black paint chips in the screens but i believe that is on the newer EFI models, can anyone confirm?
also which pump is which, high presusre & low?
one pump is in front above the water separator & 1 is in the back of the motor on top of some sort of box, also were the shredder valve is.
does this engine have a pressure regulator?
where are the screens located that get clogged?
the rear pump got brutally hot at 1 point but cooled down shortly after. the IR gun read over 150 degrees.
