At idle the oil pressure gauge reads high and pegs full at WOT. I am running SAE 30. Can someone help with steps to diagnose high oil pressure?
My research tells me the first step is plugging in a mechanical gauge to get an accurate reading. From what I can see from parts diagrams their is a sender and a sensor - one located above the motor behind the distributer, and a second down near the dipstick/oil filter. Which one is which? Where do I tee in the oil gauge?
Important background that may influence troubleshooting - I purchased this boat used. Their was a riser gasket leak that caused milky oil. I repaired the issue and changed the oil (last season). I'm not sure if that would have messed with the oil pump itself or created some sort of blockage.
Thanks for any help
Thanks for any help
