Points systems are extremely easy to hot wire. Run a jumper wire from the battery connection to the plus side of the coil. The negative side of the coil goes to the points. Crank motor, and motor will run
Electronic ignition have an additional purple wire running to the pickup
Just did that and Negative. I checked for spark at plugs, negative. Is it possible I jumped timing? What else could it be? I've replaced everything this week except the cap (that is new as of last year) I am a few ideas away from dropping it off at the shop and having to pay tons of money.....
