StingrayMike
- Aug 17, 2014
- 355
2006 Caravelle 218 LS Deck boat
5.0 GXI
SX-M Outdrive
Long story short was re-installing my steering cylinder after replacing an o-ring and the lower tab that hold the cylinder to the transom bracket broke. Don't know how, well I do, but never felt/had any warnings.
So I think my options are:
1. Pull boat out of water, remove engine and outdrive, remove plate and replace, or find someone who has experience welding aluminum
2. Take it to a shop and have them mess with it.
I am pretty mechanically inclined, and my son is a certified mechanic, so i am pretty sure we can figure it out. Just not sure on how to pull the engine from the boat. I assume just like a car. Only issue is that I only have access to a forklift and a come-along. And on that note, does the engine really need to be pulled? Or can I just remove all the interfacing parts and not have to?
Is it really worth the aggravation to do this myself, or would it be better just let the pro's do it. And if I do it myself, do i really need all the alignment tools? Since i am not fully removing the engine mounts and the same engine is going back in.
Not afraid to get dirty, just need some advice
5.0 GXI
SX-M Outdrive
