BarryTurano
- Oct 26, 2014
- 145
Still having issues I am now running 2 separators fuel is clean carb screen is clean. Was having a starvation problem at WOT. Changed out the fuel line (made it a little longer) think that has corrected the starvation at WOT. Started the boat up on Friday black smoke (first time in a long time that happened) burned off fairly quickly. Motor seemed to run well no bogging. Fished a tournament on Saturday motor seemed fine. Went to the weigh in leaving motor started right up but could not get past 3500 rpm's with out bogging down. Noticed my fuel consumption went from 13gph to 17gph at same rpm. Today I called the shop that rebuilt the new carb (Chinese parts were replaced) he thinks it maybe the fuel pump check valves sticking sometimes to much pressure because when it bogs I smell raw gas, or not enough pressure causing starvation and not allowing full rpm. It is very hard to diagnose because it is such an intermittent problem. I need some advice before I go back to my submarine training and calibrate it with a "crescent hammer", never use force on any inanimate object... just use a bigger hammer.
The fuel pump was changed when I first got the boat and I was fighting a "bad fuel" problem. The fuel was in the tank for about 3 years. I had it pumped and have run about 800 gallons of fuel over the last year and a half. I know all the bad stuff is gone now. Do yall think I'm on the right track?
