Cruzer1800
- Apr 26, 2016
- 8
Well first off, yes I am new here and seeking help. Had a 1996 Chris Craft Concept 19 for about 5 years, first problem with it. Took it out for the first time this year, overheated big time. Once back home, put on the muffs and there is NO water coming out of the engine anywhere. (Usually pours hot water out transom from somewhere) SO.. reading on here as to what the problem is. Well first off it looks like this is NOT a volvo from what I am reading... looks like a OMC or Ford or who knows... Threads all talk about check the impeller in outdrive first as that is usually the problem before water pump on engine. So I took apart the outdrive as described and I dont see any dang impeller!?!? Drive unit says it is a Cobra SV, model # 3868389 but finding info on the webernet is overwhelming. Is this one that has impeller on the actual water pump?? Before I open that can of mess, do any of you boat gurus here have any advice...I would sure appreciate it!
