I need help in removing a leaking steering ram out of a 2003 Larson 190 I/o 4.3 Volvo /penta. There are 2 pins and one bolt with cotter pins holding the larger pins in place. I need to find out how much do I take this rea engine compartment apart before getting to where I need to be. the ram leaks about a quart an hour if I drove it that much. The leak is on the bottom rod out of the piston area. These can be resealed with the correct seals installed.
