Hi there looking for some help
My friend has just bought a boat and asked me to have a look at it as wasn't running right.
The inital problem was that it was running a bit lumpy and wouldn't reach full RPM and was a bit smokey. Apparently the boat had been sitting for two years but was winterised. After a bit of investigation i found that two of the HT leads where round the wrong way and the distributor had been adjusted. So i removed the spark plugs and one of them was gunked up.
I replaced all 8 spark plugs and leads, distributor cap, rotor arm and coil pack and this seamed to solve the engine running lumpy and RPM issue.
The problem now is when it idles it stinks of petrol/Gas but runs ok, there is also alot of unburnt fuel coming out the exhaust. When I lift the spark arrestor on the carb it looks like there is two much fuel coming out the injectors at idle. Took the boat out for a run and it was ok for a bit then RPM has dropped again.
Don't have the diagnostic software to to plug in but i am hoping its something simple like a faulty sensor. I don't want to start changing control moduels etc
Any help would be greatfully appreciated
