Penta SX-M Input Shaft Seal
jastacdoss
Replacing the bellows and found gear oil in u-joint bellows. I've search around and can't find any details about the process. Can the shaft and seal be removed without removing the bearing carrier assembly?
3.0GSPEFS
SX-M 1.97
Serial: 4202020884
jastacdoss
Thanks... What other parts should I replace while it's apart? Any special tools I need? I'm a little intimidated by the crush sleeve and making sure that everything is within spec.
jastacdoss
Also, I don't have a press, can this be done with a handheld bearing and race driver kit?
