Mnoverboard
- Sep 14, 2014
- 51
Hello all, I was winterizing yesterday, and blew antifreeze through water pump intake hose and it shot out the outdrive intake as it should. However, the only thing slowly dripping out the cavity drain is raw water. Should antifreeze drip out this hole as well? I can't seem to find a schematic that shows how, or if this cavity drain communicates with the cooling system. Thanks, Patrick
