BuddhaBelly
- Aug 5, 2015
- 5
I have a Volvo Penta AQ125A engine that some how gas is getting into the crank case. I changed the oil and filter and ran it at running speed for about 2 hours. When I got back to the dock, once again a large amount of fuel was in my oil. I did a compression check #1 cylinder is 155 PSI dry,170 PSI wet #2 cylinder is 155 PSI dry, 175 PSI wet #3 cylinder is 145 PSI dry and 160 PSI wet #4 cylinder is 150 PSI dry, 160 Wet. I thought maybe I had blown the head basket on one of the oil ports. But these compression numbers look good to me. Any Ideas out there? Any help would be greatly appreciated.
